MCODECUDA
- 9:08 AM
- Jul 22, 2008
- Sherrills Ford, NC
I’m having issues with my 440 with a clutch fan touching my radiator. First her are a few facts. I’m already using a Hayden 2947 clutch fan which is the shortest clutch fans available. I can’t get the factory 3 core radiator in without the clutch fan scraping the radiator. Both the tank and the fins hit. I can not install the clutch fan after the radiator is installed because you can’t get the clutch over the water pump shaft. My future plan is to buy a new Glenray radiator for the car but I’m not about to install one with this clearance issue. I have friends with a ‘64 Fury and a ‘65 Coronet that are running similar setups and their motors set 3/8” farther back than mine and all three cars of our cars are using the factory correct K-frames, transmission mounts and motor mounts. I’ve looked at everything and there’s nothing that looks out of place that could cause this.
