Ron 73
Deceased, But not forgotton
The rotor spins, is that by hand or cranking the engine? If its the engine have you tried a new points module and reluctor? If your having battery issues, something is draining your battery which could be a number of things. First thing i would check is did or have you changed anything electrical, new radio, amp/volt meter, ect.. Sounds like your going to need a test light (12 Volt) and a multi meter to check things.. Sounds like "really getting old" it isint much comfort, but weve all been there. Have you checked the ballast resister? Get some help hold a 12 volt test light to the + side of coil and ground the other end, does it light up when you turn the key on, now when you turn it to crank, does the light get brighter?, have you tried this, i didn't take the time to read all this again, i thought you must have found the problem.
