Glenwood
- 12:39 PM
- Jun 19, 2015
- Kawartha Lakes, Ontario
I bet you're having a hard time getting that smile off your face ! Lol
Just that car sitting in the garage would bring a smile...Man I love that blue.....Congrats on the drive!You bet! Relieved as it has been a long few months, mostly waiting on parts.
That's great! I'm excited for you. That makes me want to hear mine running.
That looks great Glen! What's the weather like up in your neck of the woods?
Wow, I never would have imagined! We've been in the 108 to 112 range the past few weeks. Really tough finding a time to prime and paint my hood. Had to order the slow reducer to shoot it hopefully when it cools to 101 lol.Not crazy like AZ but it's been close to 100F with the humidity since mid June I think.
Oh man, I agree. So much stuff to mull over and order. I just got my exhaust from Jegs and its 100 degrees outside lol. What route are you taking with your exhaust? I actually used the Jegs exhaust on my 62 with a few modification and it fit great.
https://www.jegs.com/i/JEGS/555/30502/10002/-1?ymm=4294829709+4294828902+4294828881Hi
Just wondering what exhaust you got from jigs and what mods you had to make. I have a 65 and they dont have one for that year. (Headers back)
I think ghe fan is too far into the shroud though so I'm trying to find a 1/2" spacer.
I had the same problem Glenwood. I finally got tired of heat problems and replaced the factory 3 core radiator, the cast iron water pump and the flex fan. I went with an aluminum Champion radiator, a Flow Kooler water pump and an electric fan. Even with 11 to 1 compression and 550 HP, I am fine in the southern heat. She runs at 180. She will heat up to 195 in traffic and at stoplights, but my overheating problems are solved.Now only if I could drive it!
Can't seem to get it to keep cool. The underhood heat is MUCH better due to the headers and shroud, but it still creeps up too much, like 220F while idling in the shop. The timing should be right at 20 init and 34 all in with about 8-10 deg in the vac adv. Carb is tuned and I believe close with no soot out the pipes and plugs look good.
I think it is or was air locked. No flow after passing 195 with the 180 stat.
I pulled the rad to flush it just in case and pulled the high flow summit water pump to inspect the rotor, all is good. High flow 180 stat with bleeder hole tested fine which opens at 187. Wierd. Putting it back together tonight and will fill it again but jacked up this time. I think ghe fan is too far into the shroud though so I'm trying to find a 1/2" spacer. Anyone ever cut one?
Anyway, I plan to drive it to moparfest this weekend If all goes well!
