khryslerkid
- 11:40 AM
- Mar 10, 2010
- Hanover, Pennslyvania
Great info on here. I just pulled my rear out as this is the third time I will replace the drivers side inner seal. Sure enough, the two thrust buttons and broken pin were sitting in the bottom of my pumpkin. This of course allowed the drivers side axle way too much play back and forth ruining the inner seal. My question is: Will I have to replace that broken pin to keep them in place or if I am real careful on installation will the thrust buttons stay in place? Thanks!
The axle will hold them in place unless the axle is pulled out again. They stick to the end of the axle when pulling it out. Dr. Diff has new ones with the pin that holds the buttons together.
