mopar4don
Forward progress is the goal. Thank youMaking progress is always a good day. Grate looking job.![]()
Good work as alwaysSo here are the gas tank brackets welded in
And layout and fitting a piece of 1/2 black pipe for the e-brake cable pass thru tube.
So after I welded the black pipe in I inserted a piece of plastic pex (had to sand it to make it slide in) I did this to prevent the cable from rubbing metal on metal.
Good idea, I will remember thisHere's a tip. When working around the rear window, cut a piece of plywood and lay it on a blanket on the Dutchman panel. After painting my car I dented mine with my elbows and or knees while putting the rear window trim on.
I went with the 11 inch drums, hope I wont have any problemsAnd, I am jealous of that Dana. Sweet!
The alignment bar and pucks keep the ends straight and perpendicular to the center section so the axles will not bindTell us about the alignment bar and pucks.
Ah someday maybe. Just dont seem to have time to work on itHave come a long way. Looking good and hope to see the finish soon. Took me 5 years to restore my old runner. Had to do much like you did. But when finished we get to enjoy the fruits of our labor. Keep up the good work. Blue.![]()
