2007 2500 CTD Suggestions
dart4forte
9:59 PM
Mesa, AZ
I have a 2007 2500 CTD 4x4. Bought it new in 2007. The issue at hand is my wife has bad knees and finds it hard to get into the truck. I have running boards which helps but she still has problems. I’m looking for a way that I can lower the front of the truck so that it’s easier for her to get in. Selling or trading in the truck for a new 2WD is not an option. I’ve seen airbag suspension but not sure of the capacity of what’s available. Any suggestions would be helpful.
could you add a step under the running board?
You could cut a little out of the front coils and could also buy shorter blocks for the rear that might help some.
lots of guys have put in the springs from a gas truck. Lowers it some and has a smoother ride. As mentioned smaller blocks in the rear. Kim
I have trouble with my legs and put AMP research electric running boards on my 21 RAM 2500. The step is 14” above the ground when deployed.
A guy at my job used a stepstool with a rope attached to it, once he was in the bus he could just pull it. Maybe a temporary solution until you find a permanent one
Are you could open the door, put out a step stool, close the door, place step stool in bed. Easy peasy.
