Auto Trans Linkage 911
Moparfiend
9:36 AM
HOT
So I seem to be missing my hardware bag that connects my front transmission rod to the steering column. The steering column flange hole is much larger than the pined rod. So there must be some bushing that I am missing.
Can anyone help me identify what parts I am missing to join the rid to the steering flange and where I might get what I need?
Thanking you,
MF
There would be a flanged rubber bushing that fits into the lever. Then a brass bushing on the rod. There also was a large spring washer or thin flat washer I think and the clip.
Thanks you guys are right and know what I’m needing. It looks like,#43 & #44 what I need, now how do I further identify and moreover obtain these?
FNA man you’re awesome! Thanks so much! Looks like this and the cotter pin might be all I need!
Thanks again!
MF
Pretty sure there is a thin washer under the clip. You will have to source that locally.
