What's involved in supercharging a Mopar 383?
SteveSS
11:02 PM
Colorado Springs
Ever since I was a kid I liked the big chrome blower sticking out of the hood. What mods am I looking at (just the basics) and how much would it cost, ballpark. I'm sure some of you have done it. Supercharging would certainly help where I live at 7,500 ft above msl. I should probably start with a 440 I'm thinking.
Just buy a done mill from big Al's toy box
If you just want the looks and sound of the big noisy blower, go for it, but they’re really not efficient and make a ton of heat. If you really want additional power, put a centrifugal supercharger on it or turbocharge it.
I'm just after to look. The power is a nice side benefit. No, I don't want a fake one like Mad Max or F&F.
Your question makes it appear that you feel it's a fairly easy thing to build. It is not.
At bare minimum, buy a book. Read it 3 times. Then come back with more specific questions. Like " how can I machine a double keyway in my crank"
Geez guys....there isn't anything complex about a Roots type blower.
I did an early 354 for my '56 F100.
You need an 8-1 or 8 1/2 to one motor to start with. If you keep the boost under 8 psi you can use stock pistons.
Intakes for a big block are rare but available if you are patient. I found a NOS Cragar intake at an old speed shop in MA.
My 6-71 came off a 70's Dodge truck with a Detroit engine. I bought three of them from the guy who owned the trucks...$15 each!
Rick Dean @ Dean's Blowers did the gas conversion. Bought a used bearing plate and a used snout. $275 about ten years ago.
I bought a BBC blower drive kit on eBay for $250. Perfect fit...only had to enlarge one hole on the crank pulley.
You'll need a good balancer...
I made my own carb top plate out of 1/2" aluminum...had a 3x2 setup and a single 4 barrel.
Bought a Cerillo magneto but stuck with a point style early dizzy.
Clay Smith ground my cam...a mild grind for ez cruising and good fuel economy.
Had an 833 od trans behind it with a TR Waters adaptor kit.
I know I'm a scrounger and junkyard picker, I had under $1200 in the whole setup. Total cost on the whole engine build, using high dollar parts when needed, was $5500.
Guys using plastic spend that much on the blower setup.
Be patient, shop around and you can do it without mortgaging your house.
Looks like it will cost you about $14k and a trip to MN
NOT MINE
Hard to give specific answers with such a general question - especially when the thread title states 383 and you say yer gonna start with a 440 - but in general... [and the RB intake will be easier to find anyway]
The answer is... depends on what you want to do with the car. Krooser is correct; thats a good , mild way to start. If you only care about the look and whine and dont want to do a whole engine, as long as what you start with is 9.5:1 or less, just underdrive the heck out of it and go on down the road. Many years ago I built a nice, fairly mild SBC for a friend; it was 9.2, L46 cam, Pink rods, forged crank etc. He decided he wanted a blower but didnt want a complete rebuild down to 7 or 7.5, O ring the heads etc etc etc, so we just called Blower Drive Services, told em what we wanted and they sent the blower, intake, carb plates and a really underdriven set of pulleys [memory says 25% maybe?] and then bolted it all on. It did make some more power, lots of whine and a hole in the hood. It was reliable - he drove it all over including on Power tour once and used the best petrol he could find at the pump.
If you REALLY want a 'blower motor' that makes great power and will live at a lot of RPM, start with a bare block and go up. Read, read and read some more...
Totally agree. 'Big Al' aka @HEMI-ITIS has been tweaking and fine tuning his blown engine for years and is still learning. :thumbsup:
You don't just go out and bolt a huffer on an old mill and be done with it. There's a little more to it than that.
I remember back in the '80's when guys bolted a tunnel ram on their standard engines and wondered why they ran like a sack full of busted ar**holes. :rolleyes:
That 440 can live with the 500 hp it makes.The more power you want the more mods need to be done.
