Common failure, the bottom "hook" breaks off the window track. I remember brazing this one back on, in the car, back in '88.
Since it was crooked, only being welded on one side (and didn't appear it would fit through the door slot ) I cut it off and cleaned it up.
Then MIG welded it back into place straight and then cleaned up the OE spot welds inside the track that sat proud, so they don't catch the door glass slider material.
Cleaning out the track with a rag stuffed tight and acetone. Checking for any places that catch and carefully filing them smooth with a riffler file.
I learned today why the chrome and polishing specialist didn't put the window frame back together, after his $415 PER side cost even though it was quoted as Re and Re. Not sure how big a pry bar they used to take them apart, but the swage ring was still on the old bosses and the frame wouldn't fit back over them. Dremel to clean off the "ring".
I actually had to open a few holes a size up to get the vent frame sitting tightly to the front post.
Not a great start, first hit and a swagging nub snapped off. Good thing there are two. I HIGHLY suggest to anyone else, clearance the frame holes.. test fit to make sure everything sits right... pull apart.. apply panel bond adhesvie and then clamp the frame back into place over night. DO NOT attempt to swage the nubs to hold it together.
Should have experimented on the passenger side first, since that door will be seen less!
I did manage to put both frames together with only this one casualty because it moved on my bucking bar as I hit the swagging nub with the punch. A helper today would have been swell...
Chromer also increased the size of the pivot shafts so big they won't even considering going into the holders. Had to take the belt sander to them and bring them back down to size.
Now they fit..
View attachment 745087 View attachment 745088 View attachment 745089 View attachment 745090 View attachment 745091 View attachment 745092 View attachment 745094 View attachment 745095 View attachment 745096 View attachment 745097
