So many shotgun mechanics on here, just throw parts at it, and hope something fixes it ? Have you ever heard of diagnostics ? Have or do any of you do mechanic work professionally ? You can't just go buying parts and hope you fix it. This person seems to have very little knowledge of mechanics. Let's keep it simple, he said the plugs all looked the same, but didn't say how they looked, are they black ? No ? Why did you change them. Remove 1 plug wire at the distributor any wire, start the car, should run a lot worse, any difference ? No ? Something is wrong on that cylinder. Mark wire with tape, marker, or other method.Replace wire. Remove next wire in either direction, start car. Any difference ? ? Repeat procedure in same direction one at a time until all cylinders checked. Note results. Now you should have some facts to deal with. Takes no tools, no help, not much time. One other quick test you can do, remove air cleaner, make sure engine is warm enough for choke to be fully open. Start engine, cover carburetor partially with hand ? Does idle change ? Cover more, then less, what happens ? Cover carb completely with hand or close choke, engine should stall immediately ? Does it ? Report back, then maybe assistance can be given.
