My car never budged when I removed my roof skin. My car was on jackstands at the time. The subframe is pretty good support. See how the new skin lays on the frame.
Looking good Ron! Glad to see the project moving forward! I am enjoying the pics of your car!!!Getting ready to repair the passenger rear quarter panel as the original owner hit something and snagged the bumper. This requires a 3/8 tweak on the passenger bumper bracket. Reading seams and finding spot welds is definitely getting easier. Going through a lot of Blair cutting bits.
View attachment 944458 View attachment 944459 View attachment 944460
Thanks Bart!Looking good Ron! Glad to see the project moving forward! I am enjoying the pics of your car!!!
A little more prep work like:
1. Removing the primer where the 3M panel adhesive will bond the skin to the crossmembers.
2. Punch holes in the periphery of the skin and remove some of the paint near each weld point.
3. Make some MIG welding ground strap openings in the paint on the skin.
4. Finish passenger sail panel and deck areas.
5. Test fit skin and window.
What else am I missing hum......?
Thanks man I will look into this. When I scraped off the old adhesive it was like a rock. Sounds like I might need something more flexible.....Get some more advise to your #1 task. I have in the past used the 3M panel bond to bond a roof skin to the roof cross members. I was told that wasn't the correct product to use at these locations. 3M makes several types of flexible foam products that are designed for roof braces.
After I bonded the roof to the cross members in the direct sun light it would cause a ghosting effect and the roof would look wavy.
Lookin' good Ron! Pain in the *** now, but you will be very happy later!!!This Sherman panel is requiring much more fitment work than it should and what they charge for this piece. I could have saved $130 and did it myself for all the hassle.
Working on ideas on the for the marker light which Sherman didn’t put in the panel. Just another detail that has to be contended with here.
I am planing on a butt weld using a technique that overlays the new panel then tack it in. Then use a grinder with a thin cut-off at a 45° and cut out and weld up as I go. The panel falls into place with minimal gap in a controlled manor.
Nice.Rear driver quarter panel patch fitment preparation took more time than I thought it would but I wanted to make sure it was right before the final cut in and weld.
The cut in and weld went really well. I used the technique of using the panel as my stencil for cutting and cut at a 45° to have the panel lay in with minimal gap. Worked like a charm!
View attachment 946078 View attachment 946079
Nice work Ron!!!Rear driver quarter panel patch fitment preparation took more time than I thought it would but I wanted to make sure it was right before the final cut in and weld.
