forphorty
This engine ,to really fly, would need quite a bit of converter. With a stock type converter, I would expect it to be an absolute dog down low.
Click below. Then scroll down. Conflicting information?No. The 272 measures 221-222° @ 0.050".
No. The Victory Library is simply wrong, and in more than a few places.Click below. Then scroll down. Conflicting information?
http://victorylibrary.com/mopar/mpcam-tech-c.htm
I often wondered about that, 231 seemed like a lot of duration to go with .455.No. The Victory Library is simply wrong, and in more than a few places.
For the 272/.455 cam, Victory Library shows the measured duration in the little note.
Think it's the same thing as Sealed Power CS1148R.
So, MoPar lied to us then?I try not to spend too much time trying to figure out where incorrect information comes from. The Library clearly has little or no stock in "their" numbers if they put a note in with someone else's number that is completely different.
Mopar never published any true and accurate info on their cams, clearly on purpose. For 20 years they would tell you that the 0.050" duration was advertised duration x 0.85. Complete non-sense. Sad part, many people actually believed that stuff.
Oh look, just did the math............ 272 x 0.85 = 231°
Take mis-information, publish it, and it become almost impossible to unravel.
I believe 231 degrees was what Mopar advertised at the time. It's what I recall seeing on the box.
Motown Performance Cams (Wolverine Blue Racer) showed all HP B-RB cams as the same even when matching different years part numbers
Their WG-1121 matches the earlier 440 HP cam 2268405, 2532190 395 Hp 413 as 206/[email protected] 260/268 .434/.431 In 110 ex 116 or 113lca
I remember when Mopar was saying to use that equation to figure 0.050" duration, and I never believed it. I did not have any Mopar cams to measure to get the real numbers (still don't have any Mopar performance cams, haven't used one in almost 25 years.)
