Nice.
The 2315 piston will be between 0.015" to 0.020" in the hole in an uncut block. So it sounds like that is what you might have.
You can then either cut to zero deck and use a 0.040 gasket, or cut to 0.010 in the hole and go with a 0.030 MSL gasket. With the 75 cc eddy head it puts you right on 10:1 CR. You really cannot do any better for a street car. No valve reliefs in the piston is why you need to keep an eye on the exhaust valve.
I think KB has a piston that can get to to 10:1 as well, but it has a dome to make up for the valve reliefs, and will not give you quench. Kinda dumb.
This is dead nuts on
Anyways
Ran those pistons in my rebuilt numbers matching 383 Magnum .030 over for 20 years - Uncut face block , Pistons .015" in the hole like mentioned
Didn’t even know what I had in there until I pulled the heads - Was a youngster out of high school when I had the motor rebuilt with one of those kits from PAW from what I remember (Huge thick book back in the day) and didn’t write anything down other then a receipt I had from the machine shop
Ran the Mopar 284/484 camshaft and lifters straight up
So fast forward until a few years ago , Bought the Eddy E Street heads 75cc expecting slugs in the hole , was a pleasant surprise when I pulled the 906 heads and found those marked 2315 pistons in there so I know I was running something respectable anyways
Man everything still looked awesome internal
Installed the E Street Heads , Fel Pro .039" blue head gaskets , and away I went with no other changes
Lasted all of a week LOL
Got happy with the RPM’s , man it pulled with those 3:91 Gears , right up until I noticed a lifter clacking at the gas station
Had no idea until a pushrod dropped out nursing it home for five miles - Man I got lucky really lucky
Pulled the new eddy heads and saw the eyebrows , two intake valves kissed the pistons , took out the camshaft lobes and misery set in
No Super Bee for a year - I figured hell , it’s been twenty years since the last rebuild - Machine shop had the block alone all spring and summer last year - Man that sucked - Line Bored for 440 Source Billet Steel Main Caps - Cleaned up the holes and just cleaned up the decks as I know with those heads I would Bee close to 10.5-1 Compression with the new kit
Built the motor myself last winter - 383 Magnum/432 Stroker (440 Source Kit) Those same Eddy E Street 75cc heads - Comp Cams XE 275HL Ran it hard this summer - Man it spins up fast , really fast , and serious torque for a little 432 Stroker
Very very happy
