383man
I built a mild 383 that was in my Dart years ago and it ran great on the street and track for what it was. I used a stock block and pistons. I decked the block and cut the factory 452 heads I used to get a true 9.5 comp. The heads were stock other then I milled them and did a little bowl blending. Other then that I did a stock 3 angle valve job with the 2.08 and 1.74 valves. I ran the older MP .484 cam on a 104 installed centerline. Used stock rockers and shafts. I ran the Eddy RPM intake and a 750 Holley DP. CPA 2" headers (that's all they had in 1995) and 2-1/2 " exh. A 727 with a manual valve body and a Turbo Action 3000 stall tight 10" converter. 8-3/4 with 3.91 gears. It ran awesome and on McCreary G-60 tires it ran a best of 12.31 @ 110 and had great street manners.
If I were you I would call Dwayne Porter (802-951-1955) and talk to him about your build and have him make your cam. He is about the best out there with heads and camshafts. I have one of his custom grinds in my 63 and Dwayne has a very fast 383 of his own. He can guide you to build a mild 383 sorta like mine with one of his cams and some aluminum heads (440Source Stealth heads will be fine) and he will help you build a great running 383 with one of his cams that he will custom grind just for your combo. Good luck , Ron
