Wow, this is much less pressure than when you started this thread. I assume the mechanical gauge you put in is saying the same? Something isn't making sense here. When one of these engines has low hot oil pressure at idle it should come up real fast with rpm's. Especially with a HV pump. Something illogical is happening here. I don't consider this wear. This is something different and abnormal. I've torn down wore out engines with all the bearings worn down to the copper and they had more oil pressure than this, so I think it's something different. What, I'm not sure. I keep thinking back to a few months ago when I started a 55 year old Road Runner that had a stuck pressure relief. It made around 120 psi at 2-2,500 rpms.Your car is now making less oil pressure than before. When replacing an oil pump on these, the gasket is a PITA. You are twisting the pump to line it up with the drive and the gasket is giving you a hard time. If the gasket somehow gets wadded up or not perfect it can suck air instead of oil. If you leave the o-ring off of the part of the pump that sticks into the block it can suck air instead of oil. Either one of these things would have symptoms like this. Because it has less oil pressure now I have to ask. Did it go together ok?
