That_1_71_Dodge
Hello, I have a 383 Mopar that I am completely rebuilding, we are planning to put in a Purple Cam which should be a step higher than the stock one. If we do this would we have to change the pistons or would stock work better? I did some research and I believe the compression ratio for a 383 Mopar is 9.5.1, not 100% sure. I also read that it's recommended to keep stock pistons because otherwise, it'll run crappy unless running a high idle with a purple cam. If someone can let me know whether to keep stock pistons or get a different kind? Thank you
