Brand new pump though. Would it be weak already?Based on the symptoms described, this could be it.
Unlikely.Brand new pump though. Would it be weak already?
The list for low oil pressure is long, and well known. Too many things can cause it.
New 'hi pressure' oil pump? Think I read that right. And only getting 30lbs? Just me, yeah, I'd be looking at the spring, and the valve, and the valve seat. Could easily be a piece of trash, or a burr, letting the valve leak, and giving you low pressure. Even if the spring is top notch!
Unlikely.
Any evidence of the oil aerating?
Let's see, changed pumps, filters, oil, something internal I'm thinking. Some possible, plugged pickup screen, cracked thread on pickup, lifter clearance in bore or wrong for application, loose rocker shaft, bearing clearance?
I don't think he changed the pump since the potential problem showed up...……...
I replaced the pump since the problem showed up. Pressure was checked with a mechanical pump. Checked the relief spring and valve and reassembled this afternoon. Problem is gone. Idle pressure is around 20 and goes up from there when running. Thank you everyone for the help!I don't think he changed the pump since the potential problem showed up. So the idea is that there could be a manufacturers problem in the new pump's relief system.
The reason I'm leaning away from motor is that all of those things usually result in near zero pressure at idle.
As mentioned, pull the relief spring, and valve. Inspect, clean and reinstall. If you don't know what those parts are suppose to look like, take a picture and post them as they are arranged upon removal.
Also, when you checked the pressure, how did you do that? Did you use a mechanical gauge? If not, you need to do that.
Sorry, I guess I misunderstood post #9.
Is that with the motor cold, or at temp? You could have clearances too big, internally, that lowers oil pressure.Idle pressure is around 20 and goes up from there when running.
