- 4:36 PM
- Nov 21, 2008
- In GTXtacy Illinois
The oil pump seal is available by itself.
http://www.summitracing.com/parts/fel-13338/overview/make/dodge
It does not appear to come with either smaller o ring, but I am sure your local auto parts store can match one up as long as they are not bone stupid. Although not 100% necessary, I like to put the rotors back exactly like they came out. I've heard some old timers even talk about flipping the outer rotor over to provide a "new" wear surface.......but I personally don't like doing that. Lastly, a drop of red lock tite on each screw will assure they will not loosen up. (I said screw huh huh huh).
huh-huh...well, sumbitch! i didnt see it there at scummit. :icon_hang: thanks Rusty!
Since we're on the subject of pumps, does anyone besides me check the rotor end clearance? I got a newly rebuilt 340 in several years ago that had lost pressure. The drive shaft (intermediate shaft) had failed and when I removed the pump, it was stuck. After pulling the cover off, I found that there was only .001" clearance on the rotor measured with a depth mic from the body. A tiny bit of trash got lodged in there and it killed the pump which pretty much killed the engine. .001" isn't really enough with .002" being what I shoot for and .003" being max.
And on your cover leaking, you only have the two small screws holding it on and they are really more about keeping the cover in place so you can install the pump without it flopping around. Once all the other screws are in place, it shouldn't leak unless the o-rings are bad. They are usually trapped in there pretty good tho and usually they don't leak at that area. Also, while it's apart, you could take a straight edge to make sure it's flat.
Thanks Cranky, ya i might as well take it apart and check tolerances. good insurance me reckons. the manual shows all the places and procedures to feeler up, so ill go with that. :read:
thank you kindly Gentlemens
