don't forget to hang some plastic up to keep the overspray from getting everywhere.
Especially the brick lol.
I know, But I got a good laugh out of it myself!Oh boy Daytona Kid . . . You're NEVER going to live that one down . . . ( sigh ) . . . ( smile )
I wonder if these are any good?> http://www.ebay.com/itm/mopar-A-B-E...dge|Model:Charger&hash=item4d02f86ba4&vxp=mtr
The blasting opened up a few more rusty spots, so I've been working on them before the primer. I've have found a method that works very good for small hole patching. I use the pointed end on my body hammer to open the hole to good metal, rolling the thin weak metal down, forming it into sort of a bowl with no bottom. Then fill the bowl with weld, starting outside working in a circle to the center, and grind smooth. The bowling of the hole keeps it from burning thru so easy and makes a strong repair. In the areas where needed, I go inside and grind smooth also.
Thought / question - after making the dish, why not stick a small piece of good patch metal in the hole and then weld it ? ?
Question for you guys.. Is my 383 K-frame going to work ok with a 440?
I think they are the same for both but wanted to make sure.
