68 GTX Project
ok so progress continues.....was chasing a squirrel this weekend and instead of fixing this:
I did this: ohh my so many squirrels to chase!
New project....the parts washer. works great and will come in handy!
That is awesome! What pump are you using and what solvent?
Parts off the bench! Fullish restore of pedal and clutch set for the 68 B
Pixs of the rear axle build.....almost done and off the bench
man that was a cold day I brought the chunk in from the garage.
original yoke and the stub shaft for aligning and supporting the assembly.
You're making some great headway and the quality work really shows. Love following this thread and seeing the product.
Some body work headway. Getting my skills tuned up for sheet metal welding.
I've been slow on the "uptake" with sheet metal welding, but this was a big confidence boost!
Finishing up on the passenger side wheel house.
20170621_142857.jpg 20170701_113234.jpg 20170701_113257.jpg 20170701_130029.jpg
the driveway metal shop! LOVING the new cart...makes setup a quick
More progress
BTW Fxxxx weld thru primer. It blew up my plug welds! Sucked
New $10 german made dolly set from ebay. Loving those...got a steel or is it steal on those!
A nice surprise found under the trunk floor extension.
I saved the old corner reinforcement that I dug out and then semi restored to test fit everything. It fits way better than the AMD replacement, but I'll have to work on that. (hence dollies!)
20170703_171307.jpg 20170708_175501.jpg 20170708_175512.jpg 20170708_175532.jpg 20170708_195003.jpg 20170709_142123.jpg 20170709_162417.jpg 20170709_173636.jpg 20170709_174712.jpg 20170709_174909.jpg
