Heater Box Resto (Pt. 2)
At this point the core should just pull right out. Pretty easy to tell if they've been leaking as you'll see the green-ish copper corrosion on the fins like mine.
IMO the core should be pressure tested any time the entire box is out of the car (not fun to do if you ever find it leaking when everything is already installed in the car), I took mine to a local radiator shop that tested it for me for free.
Turns out the corrosion on mine was caused by a leak at the base of one of the fittings, which then ran down onto the fins. Luckily an easy fix, the radiator shop just re-soldered the fitting, re-tested it under pressure for 1 hour, and with no leaks called it good as new for only $10. :icon_thumleft: If there had been leaks in the tubes, you can find replacement cores on eBay through a few different companies for $50-60.
But while the core was in the shop I took the time to clean out all the dirt and dust from the housing with some wet shop towels.
Then removed the plastic finned piece that had some decent buildup (just a couple screws holding it onto the housing) and scrubbed it with a combination of warm water and dish soap, and an old toothbrush.
And cleaned up the foam insulation pieces for the core fittings
Then I removed the plate that the blower motor attaches to (only held to the housing by hex head screws around the edges) and gave the inside of the housing a good wipedown
Going back to before I started tearing everything apart, I hit the plates with red (coarse) scotchbrite pads to remove that minor surface rust I mentioned
Then with the plates removed hit them with etching primer, then topcoated with Martin Semour "underhood black." I also took the time to tape off the metal pieces that are riveted to the housing (the brackets where the vent cables attach to the posts) and gave them the same paint.
So now with everything painted, the heater core repaired, and the box cleaned out, everything just goes back together in the reverse order as taking it apart. (secure the heater core, re-attach the back plates) Here it is all painted and buttoned up :icon_cool:
So there ya go guys, there's really not much to it taking one of these things apart and cleaning them up, pretty simple stuff and it should go a long way for the air quality inside the car whenever you need to throw some air through it. Like a buddy of mine told me about deciding to tear his all apart, "I don't need to be breathing no f***** air from 1969" haha
ccasion14:
