daytona kid
Great looking motor art there SF!:VB toast:
Hi all. New to site as well. Dig the stance that charger has.
Next, on to prep. I scraped the old silicone/sealant gunk off my valve covers and gave em a good degreasing with denatured alcohol
Then laid down a bead of Permatex Ultra Black rtv. We use it on the cnc machine enclosures at work because of how well it holds up to oil, so it should do the job.
Then laid the gasket on, pushing it down onto the rtv with light hand pressure. I know quite a few people use cork gaskets without issues, but I went with these Felpro "heavy duty, high heat" gaskets after reading a lot of good reviews by other members on here.
Also got my trans dipstick installed, and found a good spot for it on the firewall. Works good and I think it looks prety clean where it's at
:icon_thumleft:
Now back to the roadblock on the driver's side of the engine.. I got my Lokar dipstick last Friday, looked really nice. "Looked." When I went to install it, it was a fairly tight fit, but I oiled the fitting and it went in as far as the first o-ring without much hassle. At this point I'm working it in and the fitting just snaps right off in the block at the thinnest point where that first o-ring is. :banghead: I noticed on the rest of the fitting how thin it was, brought it to work this morning and measured it with a digital caliper to find the wall thickness at the point where it snapped off was only .016"... "Are you sh!tting me?" I emailed the lokar tech guy I was talking to before I bought the dipstick letting him know I'm not too happy, but no response as of yet.
So I guess I can turn the OD down on the lathe a bit to re-use what's left of the fitting and get it to fit easier, but I'm still left with that piece stuck in the block. I tried a (Never) Easy-Out but with no success. Just spun on the top of what's left of the fitting.
Everything is looking great Speedy - except for the dipstick roadblock. And here I thought it was only me that had problems like that. It seems like nothing is ever easy when restoring an old Mopar for some reason. I've got my fingers crossed hoping your Lokar salesman will give you another one.
Best of luck SF....That would be enough to torque me sideways as well. Hopefully your mod tool does the trick for you. I take it that the dipstick material is aluminum?
Thanks man! And yeah that's possible but I'm trying to avoid dropping any filings of aluminum down into the pan that would probably happen if I chiseled it. Worst case scenario, is it possible to drop the pan with the engine in the car?Any way you can cut one side with a chisel (small sharpened screwdriver or something) then use your tool to pull it out?
Don't know if I would want to push it down, I think the hole tapers a bit, might be more headaches.
Could push it up from under if you feel like dropping the pan.
if you can't get your tool to catch the tube, try tapering the bottom of the notch back a bit so it has a bit of a point to grab.
Or if the tube is that thin can you get something between the tube and the block and collapse it in then grab it.
Good luck, everything else is bad *** dude, you are the man.
Aren't you a little concerned about it getting into the motor? You've got lathe skills, how about turning your punch like you said but them offset it in the lathe and machine a lip at the end that will get ahold of a larger area of the bottom of the broken stick then put it on a slide hammer. "Probably not enough room for a slide hammer" I'm sure you'll get it straightened out and if it's really tight your idea will likely be just fine providing the hole is deep enough "good luck".
I'd be to nervous about having a piece fall into the pan without knowing it. I think I would pull the pan and tap the piece up with a punch.
Cool that's what I was hoping, just got under the car and looks like it wouldn't be a big deal to drop it if I have to. There's my plan "D" I guess hahaPan will come out fine, drop the center link and out she comes.
thats why I thought afterwords about collapsing it in and not making small pieces.
Let us know how you come out with the dipstick. I've got the same problem. Are those heat guards that you have on your plug wires? never seen 'em before.
Oh and can't forget the BFH, Stubby Edition. Here goes nothin!
