70 Hemi Superbird Restoration..................errr.....scratch that........
Fun with fiberglass… ugh. The deck lid was oddly shaped along the front and one side had 3/8 taper and both needed material added. I ran out of resin this weekend or it would be done. The template is the shape it needs to be in order to match the car.
The engine bay is coming along. One of my buddies is spending way too much time on it, smoothing everything lol. I would’ve knocked the weld berries off and painted it. We cut the openings in the firewall for EGT plug bezels. You can see one over on the passenger side. Other than that, it’s fairly stock looking.
The nose got wet sanded and buffed today. The trim and some other parts got blasted and epoxy primed. We’ll put the nose decals on after Christmas.
Any tips for taking a curve out of a hood or adding width? About .25-.375
Thanks
Tim
Thanks
Tim
Fiberglass, I assume ? I added over 1/2” to this trunk lid by tapering the original top and bottom edges back about 3/4”. Then, with the lid on a stand in the upside down position, I used a piece of sheet metal clamped to the top surface deck lid as a support for the first layers of fiberglass matt. Wax paper keeps the fiberglass from sticking to the sheet metal. After that cured, I flipped it over, roughed the cured layer with 36 grit, and added more layers on top. The cured bottom layer will then support the new glass matt and resin added. The curve is a bigger challenge and I have yet to tackle that. My hood has a lot of curve to fix.
I need it to just be all one color, even if it’s primer, lol. I can’t wait to get past this bodywork stage into paintland….
Beautiful, coming together real nice!
Can't wait to see it go on a road test!
Added the battery shut of switch, made the inner fender extensions, borrowed a buddy’s wheels for mockup and rolled it outside for a photo.
Quite a bit of work on the trunk to get it this far, but the fit is starting to get there. Still lots of work needed.
The nose is complete with the headlights and actuators and is very quick and easy for two people to take it off and remove it. It had to be removable for a race car and the interlocking mounts make it easy.
Finished up the lower pans mentioned earlier to hold my fender extensions and allow the lower center pan to be removable so I can stand up against the radiator yoke when working on it without having to lean over two foot of nose and another foot of latch tray. Poor nose got booted out in the cold.
