70chall440
- 8:01 AM
- Feb 11, 2018
- Yelm, Washington
Also got my intake assembled.
You are making me look bad! You’ve got more done today than I’ve done all month.Worked on getting the intake installed, the radiator hoses on, the rear window defogger finished and the spray shields on.
View attachment 1550639View attachment 1550640View attachment 1550641View attachment 1550642View attachment 1550643
LOL well I'd apologize but.... LOL its not a race plus I am 100% retired so I can work on it all day every day if I choose to. All that said, it is starting to take shape but I've just run into an issue that is going to slow me down I think.You are making me look bad! You’ve got more done today than I’ve done all month.
That's clean looking. Mine is a bit rotted out there and I will most likely be relocating my battery, so I might have to steal this idea. How did you attach it?One thing I kind of forgot about was the battery tray area, I had planned on cutting it out and welding in some new metal but kept putting it off, well today I finally really looked at it and decided just to make a cover plate and call it done.
View attachment 1552780View attachment 1552781
Thanks, most of these cars have that area rotted out due to exposure to battery acid for 40+ years. I will be locating my battery in the trunk as well and as I said, I meant to cut this area out and weld in a plate but forgot about it.That's clean looking. Mine is a bit rotted out there and I will most likely be relocating my battery, so I might have to steal this idea. How did you attach it?
@HEMIB I looked at that as well but there just isn't any room. I looked at possibly trying to find some thinner lines but no real luck plus I already had all of the of the other stuff. I am currently using some banjo fittings from CPP which use O rings which I don't have a lot of faith in. I just found some better banjo fittings from Unisteer which I ordered.Those HB lines are always hard to get neat i put an AN-6 u turn on the box so the lines went under the pump what ecu are you using
No I have not had it running yet.Have you had it running with that manifold what's the idle like, did need an adaptor for the air cleaner
