71airgrabberRR
Today I was able to get a whole lot done on the Challenger.
I started out by removing the rear window.
Then I pulled the vinyl top off to see what was lurking underneath.
Luckily it wasn't too bad under there. But my opinion started to change as I dug deeper into it.
Then I continued to cut away at the "Dutchman" panel and rear quarters.
I found a whole in the driver side rear inner and outer wheel house just where the two parts joint together. If you look closely at the second to last photo you can see the light shining through the hole.
This hole was lurking behind the seam sealer. Once I removed the sealer the hole appeared. I also noticed the trunk floor had a small pinhole in it as well. I'm not so sure it will turn out so well after it's been blasted.
So it looks like my project just got more costly and time consuming to boot.
But the car will turn out better once these parts have been replaced.
I'm going to get a new roof skin, trunk floor and inner and outer rear wheel houses for both sides. I've been toying around with the idea of getting a set of hood hinges and exhaust heat shields for the Challenger while I'm on a roll.
You all take care.
You all take care.
