71airgrabberRR
Today I tried to mow our yard................... Mother Nature had another plan though. I got the front half mowed and was headed back to mow the rest of the yard. Then it started POURING rain..............
So I parked the mower and started tinkering in the shop. That's when I noticed the timing cover wasn't cleaned for the 440 engine that will be going into the Challenger.
I went to work at it....................
Once I degreased it, removed the old front seal and gasket material, it went into the glass bead cabinet.
This is how it looked afterward.
To keep it from flash rusting with the humidity, I sprayed a light coat of clear engine enamel on the inside of the cover. Here the paint is still wet. It dried with a "semi-gloss" sheen to it. That could have been due to the light amount of paint applied or the humidity today. Either one could have done it................
Once the inside portion was dry, I sprayed another light coat of rattle can "Hemi Orange" on the front.
I didn't want to go crazy with coverage because the whole engine will get sprayed using my spray gun.
It's not much, but any progress is progress.
Have a good one...................
