Lots of good work going on here!
What is that P/N of the neg. battery cables? Are they still available from Ma Mopar?
Thanks!
I bought the standard 9" and 18" tongs and I also have the 18" TT-9 tongs that I use the most. I filed the tips to match the original spot welds as the new tips are to small. Plan on making a cart to mount the timer on and hold the spot welder.
good luck!
Pat
I just stopped by our local Dodge dealership and the cables are still available.
They list for $89.95 and they have 12 in stock at the distribution hub.
Part number is 02983778
Hope this helps.
They offered a cart for it but didn't have any pictures of it. I will check it out when I pick up the welder to see if they may have located some more info on it. Otherwise I will be making one for sure. Thanks again for all of your help.
Now I have the cold air assembly and ram air box for my 1500 Ram.
Looks like I have to spend a little time working on the truck now with the exhaust system and hood swap. I'll post up some pics here if you all don't mind.
Later folks !!!
Now I need to get the correct 220 V outlet for the chord so I can start using this bad boy !!!!!!!!!!!!!
Darn, the pics arent coming up for me right now......we're going to buy a wire feed here soon, going to run some pipe in the fake pherrari.......Good Luck w/ the Miller spotter.I was able to get a LOT done over the last few days. To begin with I picked the new Miller spot welder up...........- - - Updated - - -View attachment 308172View attachment 308173View attachment 308174- - - Updated - - -I used my old blue cart from my MIG welder...............Now I need to get the correct 220 V outlet for the chord so I can start using this bad boy !!!!!!!!!!!- - - Updated - - -View attachment 308175View attachment 308176- - - Updated - - -I was able to remove all of the old paint and body filler from the trunk lid. Then I glass beaded it down to nice clean metal...................I also glass beaded the rear lower valance, tail light panel and K frame.- - - Updated - - -Then today I sprayed these parts in black epoxy primer.- - - Updated - - -View attachment 308177View attachment 308178- - - Updated - - -View attachment 308179View attachment 308180- - - Updated - - -View attachment 308181- - - Updated - - -View attachment 308182- - - Updated - - -View attachment 308183- - - Updated - - -Then I had to set the tail light panel in place just to see how it looked.....................That's all for now. The new season of "Vikings" is coming on. Can't miss it. Later folks !!!!!!!!!!
that truck looks like a beast with the ram air. Your going to have a brand spanking new car when you get done. Are you going to try for a gold certificate?
rr Tor-red, I'm pretty sure the first part number you mentioned is for a Positive + cable and not a ground -.
The part number I mentioned was for the ground cable. That's what I thought you were looking for. When running headers I agree that a longer cable would give you more options.
I was referring to P/N 3764166. A positive, 43" long cable
