Maxxx
Thanx Bob for your input, I'll do some research on all your suggestions, unless you or anyone knows the most favourable heat range / gap style / firing end metrics for my 400ci?You can always consider a "short" external insulator spark plug available from several manufacturers, such as Champion CJ series (CJ--8Y series) OR NGK (BJR7 series) in equilivant heat range to what you are presently using. These for instances are assuming a 3/8" reach plug. If your preference is NGK, refer to their heat range and gap styles and firing end configurations. NGK offers a plethora of plugs in their offerings. The same holds true for the other manufacturers......call them to verify....just my opinion of course.
BOB RENTON
And 3/8" reach refers to what? The height of the insulated contact extending from the block?
