70chall440
- 9:43 AM
- Feb 11, 2018
- Yelm, Washington
Here is a RR I did
How have you mounted the union bracket? Since the Wilwood cables have a sleeve, it has to be anchored somewhere.I ran my cable through my SFC as I do all the cars I build. I cut a hole/s base on the angle and many times put a tube through the SFC and weld up each side just to maintain the strength or I make covers around the cable to cover up the but hole. Normally the tube needs to be smashed a bit and be more like a oval.
Somehow I completely missed your pictures. Were the plates just temporary or was that just a separate car?
The first 4 pictures are of the Roadrunner I did and the plates are to clean up the hole which is much larger. The last 2 pictures are of pass through tube I put on the same car to accommodate the fuel lines but I showed it to demonstrate making and installing an oval tube into a frame rail or in this case it was a cross member.Somehow I completely missed your pictures. Were the plates just temporary or was that just a separate car?
I just rented one from the auto parts store.It looks good, what kind of flaring tool do you have?
Gotcha. I have all manner of flare tools (and benders) because I became a bit obsessed with the subject. I have a hydraulic flare tool that produces perfect flares every time and does 37 and 45 degree flares (AN and Brakes essentially).I just rented one from the auto parts store.
It looks like the calipers are fixed, if so then the hard lines would be ok.By the picture it looks like you ran hard lines to the calipers. You need flex lines there, to facilitate caliper removal for pads etc, about a foot long then hardline line from there to tee.
It looks like those calipers slide, therefore you would need flexible lines.Hmm. My Doc Diff set uses them.View attachment 1554114
