ckessel
Gotcha.
Even with fixed calipers I do a flexible line to facilitate the removal of the caliper but you can do hard lines to them as well without issue because there is always a slight amount of flex that will allow removal.Gotcha.
I considered that, but the pads come out the top after pulling the long cotter pin. Also the calipers are fixed, not floating like most OEM style. Therefore you don't need the flex to allow movement. Only time I'll need to disconnect the line is when I'm pulling the rotor for some reason.By the picture it looks like you ran hard lines to the calipers. You need flex lines there, to facilitate caliper removal for pads etc, about a foot long then hardline line from there to tee.
Looks good.Installing the shocks was harder than it should have been. I have some suggestions for Ridetech, but I got them in.
Also got the car back down on all fours. I was worried that there wouldn't be enough drop in the back, but that's not going to be a problem.
Back needs to come up and the front needs to go down. This new system doesn't have bump stops in the back. Any thoughts on that?
The cross bar bolted into one of the holes where the bump stops was. It might still work, but I need to look at it more. The shocks have a built in bump stop on the shaft, but it might not be enough.Looks good.
I would definitely fab up some bump stops, are the stock ones at the top of the frame arch over the rear end too thick?
Yeah I'd probably fabricate something other than what is on the shocks.The cross bar bolted into one of the holes where the bump stops was. It might still work, but I need to look at it more. The shocks have a built in bump stop on the shaft, but it might not be enough.
Read above for why I'm not using a using a flex line. I've got the coilovers at the lowest setting right now. There's plenty of adjustability left to bring them up to where it needs to be.You should be using a flex line to the caliper and those shocks seem to need stiffer springs.
A lot of this I know, but that's a super helpful post, the kind of post that makes this site so great. Thanks for the time and advice.I don't know your experience level so if I am way off base just ignore this but I have done this a few times already and here is my advice;
1. Highly recommend a battery disconnect, with all of the electronics it is beneficial to be able to turn most of it off with one switch (other than the ignition).
2. Since you are going to be using the stock harness, you are going to need to tap into the ign 1 and 2 circuits (blue and brown wires coming off the switch). You can do this several ways but one of the best is to use a relay. If you search online you will find the diagram.
3. You MUST run your ECU power and ground directly to the battery or you will end up with issues down the line.
4. Most of the problems experienced when putting EFI or a G3 Hemi drive train can be traced straight back to the lack of or bad grounds. You MUST run a solid ground to the cylinder head/s. The Holley kit comes with 1 wire for this purpose but I recommend you run another to the other head.
5. Use relays for anything and everything you can.
6. Use an additional accessory fuse box/power distribution. This will provide a fused accessible location to run any and all accessories for both power and ground. I usually use something like this; Amazon product ASIN B001P6FTHC
7. I crimp and solder every joint/connection. I know there are those who say that soldering isn't necessary and in some cases detrimental, however having done Mopar wiring since about 75 I hate having crap fall apart. I NEVER use those crimp on connectors that you get at all the auto parts stores, I remove the insulation and then crimp/solder and heat shrink them.
8. Most of the connectors you will find in your car are Packard 56 types which are available but there are a variety of types out there so be prepared to get pissed off some... lol
9. good tools are a must, however there are so many out there and most are not cheap. Here are the 2 I use the most and will do 80% of all electrical needs.
A. Amazon product ASIN B071KFLY43 B. American Autowire CRIMPER DOUBLE 510586
10. Lastly, if you don't have a digital copy of the factory Chassis manual (not the body manual) you need to go to www.mymopar.com and down load it. Go to chapter 8 and print off the diagrams that apply to your car/situation. I also draw all my own diagrams for anything outside of the factory on Power Point (easy for me), things like the switches, accessories, etc. and I have everything in a large 3 ring binder for reference.
Bonus - bench test a much as you can, saves a lot of time.
Yeah that box will work if you need that many relays (which you might). This is the relay/fuse box I use for the headlights and another one for driving lights if I have them. It is great because it is small and water tight. Amazon product ASIN B00HKIHHROA lot of this I know, but that's a super helpful post, the kind of post that makes this site so great. Thanks for the time and advice.
I was planning on using a relay box like this:
Relay box
I've been tracing the wiring diagrams. I hadn't quite figured out which wire was the accessory and which one was the "on" or "run" (blue and brown wire).
