Alcohol in gas
Is anyone out there sober?
I am now. I might have a sip after I arrive at the mother-in-laws later tonight. :rofl: :rofl: :thumbsup: The photo above is les than half of my collection. I am a few short of 500 bottles. I have a collecting problem.
:lol:
Better than a drinking problem.
Seriously though, to be able to have a collection like that is good, shows you have restraint.
I know people who would have 500 empty bottles.
It's 35 degrees out. 10% ethanol in the gas, even the winter blend ain't cutting it. Plus the heat riser is inoperative. Before this summer the car hasn't been fueled since the mid 90's. I've been running the engine just this year on gasohol, and I needed to start it today to get stabilizer in the pump and fuel bowls. So I start my 67 440 H.P. "max wedge style". Close the choke, start it, and ride the gas pedal for about 4 minutes at 1500 rpm. Then shut it off and let the intake heat soak for about 4 minutes. On restart it idles at 700 rpm nicely.
Because of the low vapor pressure fuel in the NY metro area, I am in the process of putting a manual control cable on the heat riser flap. The thermostatic spring is gone and the flap defaults to open. I put a 2" threaded standoff on the bottom of the counter weight clamp screw (10-32 thread) to serve as a lever. When the Dorman manual choke kit comes I'll use the cable to control the flap from inside the car. Pull to close the flap, push to open. In the 80's I ran a manual choke on the carb (it prevented the car from being stolen one winter in 1987). I've since gone back to automatic choke mode and locking the garage. I'll update on the success of the manual heat riser control when I finish.
Use this for ethanol fuels.
Works better than regular Stabil.
The wonders of modern chemistry......miracle in a bottle......just like the little blue pill for men...but for your car....must be those "enzymes" that are the key ingredient......what ever they are.....?????......just like the witches brew in Macbeth..7
is a mysterious potion with a long list of ingredients that includes:
  • In Macbeth, the witches' brew is a mysterious potion with a long list of ingredients that includes:
  • Eye of newt: A common name for mustard seed
  • Toe of frog: Buttercup
  • Wool of bat: Holly leaves
  • Tongue of dog: Houndstongue, a toxic weed
  • Adder's fork: Adder's tongue, a spring flower in the lily family
  • Blind-worm's sting: A reference to a tiny snake
  • Lizard's leg: An ingredient in the witches' brew
  • Owlet's wing: An ingredient in the witches' brew
  • Fillet of a fenny snake: An ingredient in the witches' brew
  • Tooth of wolf: An ingredient in the witches' brew
  • Root of hemlock digg'd i' the dark: An ingredient in the witches' brew Eye of newt: A common name for mustard seed .
  • Just a thought......
    BOB RENTON
    BOB RENTON
You're making me hungry. LOL!
I don't run into these issues and never run a choke. I can start my stroker 499 below freezing with a 6 pack or a 950 brawler at 32F with 10% ethanol blends. Maybe you have a different problem?
Update: the manual control cable is now controlling the heat riser flap.
Pic. 1, flap closed, pull on control cable.
Pic. 2, flap open, push control cable in.
Pic. 3, worn out spring.
The control cable "pull end" is mounted under the dash, as would be the control for a manual choke.
Pic. 4, the cable was routed through the antenna cable hole in the firewall.
