Eric F
- 12:09 PM
- Jan 22, 2023
- Atascadero California
when I and the front end guy did the alignment on my 70 Road Runner at the dealership. I had manual steering still . We set the caster -1/2 degree and camber @ 1/4 positive. At that time I was running 225/70/15 front tires 255/60/15 rears.The specs are from the 1970 service manual for manual steering still.
I have converted to power steering. I’m doing lower control arm bushings and strut rod bushing. I’ve also changed my front tire size to 255/60/15 rear tire size 275/60/15. Power steering spec’s are caster 1/4 to 1 1/4 positive. Camber 1/4 to 3/4 positive. I’m thinking is if I can squeeze 1 1/2 plus on the caster (no sure if the stock upper control arms and eccentric’s have that much adjustment) keep the camber @ +1/4. ( modern Charger 8 plus degrees caster. -1.0 degrees camber) even with a firm feel box it’s pretty light feeling. Thoughts?
