troyintahoe
I was working on my rescued roadrunner today. It has been cutting out abouve 3,000 rpm's. I got a timing light on it today and noticed the light was cutting out above 3,000 rpm. Started checking with the Ohm meter. Coil was not putting out proper.
Discovered my ballast resistor was assembled from the factory backwards!
I cut the dowels off of each of the two prong plugs for the resistor. Plugged them in backwards and bingo! My harness had never been tampered with, so I guess the only possibility was the resistor was built backwards, from the factory.
If you plugged into the resistor either way with the little dowel in the slot the correct way, It would not work properly.
It was an O'rilley part, buy the way. Crazy......................
Anyone else ever have this happen, or am I the only one? Troy
