Seems to be very good advice. Locking out the distributor and putting a start retard on is the same as mag starting without the issue of the having a switch to deal with. My question is, have you tried any of it yet? He's dead on with your oscillation issue. Those blue springs won't work in this deal. I think mine has orange springs in it right now.this is copied from a msg I got from Damon at diamond back engines, he has many tech articles on tuning especially mopar engines, thought I would share what he told me to do.
"Several things here, will try to address the obvious.
First off the combo of the CH28 and small carbs is going to make for very high intake tract speeds and a narrow tuning window. You would be better off with a larger plenum intake and or larger carbs at least 625's. That said you need to tune it fully warmed up. ...properly tuned, not counting any choke action, the rise in rpm is normal which is why you cannot tune cold as the engine will be lean. I would guess a lot of your run on problems are related to throttle opening and rpm. Tune to a 850-950 hot idle speed. That cam should want 18-20 degrees of initial and about 35 degrees total. With that said, you may need to put a switch on the coil to allow mag starting ( get the engine turning on the starter and then turn on the ignition) to allow starting with the proper tune. Another option is a very light advance spring to allow starting at low timing and when the egine starts the spring expands immediately allowing proper timing. The surge could be ignition related or your metering rod springs may be a bit light allowing the metering rods to oscillate at cruise rpm going rich,lean, rich, etc. one way to test that theory is to increase cruising speed 10-15 mph and see if it smooths out, if so go up to yellow springs. Have to get busy, that should give you something to work with for a bit."
Benno,
my understanding is the 500 and 600 eddies are the same carb venturi / throttle butterfly - the 500 booster cluster is different size and takes up / restricts the air flow , as you have 500's I would set them at 1:1 at least to start with though I see no reason it can't be tuned to run progressive. I have 2 x 600 eddies on the Modman . Currently I have a Victor 440 with prosystems 1000hp based carb .
Hemirunner is right , if you are not using a oxygen sensor you should whether it be on the dyno or in your car . Just bought a Autometer from Summit for under $300 for a mates Camaro .
With the dual plane and 500 carbs I would maybe like to see a little more vacuum at idle .
What is your ultimate aim . Greg's 510 I tuned went about 440RWHP with a solid FT cam I chose , using his limits , and a sixpack , but with mild worked eddy heads ran out of cylinder head flow and could not get the AF ideal due to this . I had the same issue and went to CNC port heads whohoo what a difference I ended up with just under 430RWHP out of my 440
Tex
Damon knows his ****. I,m running one of his carbs on my 500. Its very common to see him tuning carbs for people at the track. I trust his advice.
ultimate aim is to have a healthy motor that doesnt overrun etc. more of a street cruiser with a couple of circuit days and strip days a year.
i was reading moparmusclemag did a 505 build with very similiar build to mine, it had higher compression but smaller cam and it was pulling 650hp 690tq at the flywheel and was using dual 500 edelbrocks.
where i live is a mining town, there is no dynos or experienced engine tuners for 1200 km, so everything will have to be done by me with the advice of you all.
Benno ,
buy an in car AF meter unit . At least then you know what is happening , and buy 2 eddy strip kits and mark them to front and rear carb. If you get 1HP/ci you have a mighty fine motor and this is easily achieved - you should be there by now easily . But once you get over 1.1/1.15 HP/ci you are getting to a point of less street friendly manners and the trade offs that go with it . The magazine numbers I take with a grain of salt .
hang in there ,
Tex
nah no single setup, idle at the moment with 2 1/4 turns out of the A/F the idle is sort of steady around 7-9hg
Benno ,
hang in there ,
Tex
can you recommend AF meter unit?
what are eddy strip kits?
