jenkins71
Hi Guys,
I am finally assembling my 440 build. Everything went good with the rotating assembly, but unfortunately today I had some set backs putting on the oil pan and rear main!
First, the rear main. In my Victor Reinz gasket kit, they only provide you with the two semi-circle halves that seal the actual rear of the crankshaft.
They don't come with the little side "strips," and say to squirt RTV in the channels instead. I did that once, and the gap outside the channel (between the block and the seal retainer) was too big so that the RTV squeezed out the sides before it could reach the bottom of the channel. So I took the retianer off, cleaned it up, and started again.
This time I put a bead of RTV on either side of the channel, and pushed the retainer into position. I let the beads dry, then squirted my RTV down into the channel. It went okay. Do you think this will work fine? Anyone have experience with sealing the rear main using RTV instead of side-strips?
Or should I re-do it again using a kit with strips?
On to the oil pan. After I got everything cleaned up, and the windage tray too, I put down some RTV on the block, then a cork gasket, then the windage tray, then more RTV on the flange, then another cork gasket, then some RTV on the oil pan flange, and put the oil pan on. Took a long time to smear everythign around. Then I go to tigher the oil pain to 15 ft/lbs, and not only does the oil pan deform under the torque, but the gaskets squeeze out and then ONE OF THEM RIPS!!!
ARGHHHH., After all that!!!
So I went ahead and ordered one of these one pice windage tray/gasket deals from Jegs:
http://www.jegs.com/i/JEGS+Performa...xYoQMDQij-skdFiTcemYNTpYopSLa5TjvQaAkFU8P8HAQ
Anyone ever use one? I hope I bought a good product.
Anyway, thanks for any gasket-related advice!!! This is not my first time doing gaskets, but IS my first engine build!
