like govt. work ? oh, It's good enough
IMO above 120mph in the 1/4, you should upgrade
even a street/strip car at them speeds
especially if you don't use a chute to slow you down before getting on the binders,
like pros always do)
& IMHFO when it comes to safety, take or or leave it I don't care
you should always do above & beyond what you think you will need
you
will never regret having a better brake system
you don't have to break the bank either
there's OE systems, Disc or larger better drums
that will do better than any 9" or 10" drum (that's nucken' futs on a racecar)
easily, whether you need it or not
when you need it, they will be there
use a proportioning valve too
either an adjustable or
even a good factory one/new designed for your application
Drum Drum, Disc drum or Disc Disc
I like a good brake system on my cars
especially street/strip cars, more so up here in the
windy *** country roads, steep hills & valleys
& no brake fade or crazy heat, with at a min. front disc
vs even the big *** drums factory HD 11" x 3" fronts on a RR
on a dedicated racecar, it's mandatory for me
I budget for it
some people are just cheap, period
it's not a place to skimp, or to be cheap
Lets see;
You'll spend a fortune building the cars;
maybe $10k+ paint & body, or far more time & efforts
let alone the price of buying the car to begin with
thousands on engine rotating assembly/machine work etc.,
thousands more on cylinder heads, porting, roller camshaft (if you go all out),
thousands more on induction systems/fuel system/carbs or FI
thousands more on trans, converter/clutch, rear end, suspension,
the driveshaft, adj. shocks, the seats ignition & cage
thousands of dollars more in wheels & tires,
to all be bulletproof etc.
& yet you go the cheapest **** with brakes ?
(that's not a question it more a rhetorical statement)
good brakes have saved my *** many times,
so has a good chute or 2
& I've been 6.69 @ 217 in a full-bodied (with ballast) 2800# car,
been 5.97 @ 227 in a RE/TA Dragster
I've been on fire @ 140-180mph (more than once)
& I was certainly glad I had great brakes (good chute/s)
it's your life, do what you think is
'the best risk of it'
what's that price worth ?
at what point is it worth it ?
you only have 1 life
carry on
