Ballast Resistor Bypass
Msd doesn't want a resistor to be used with their box. Use the coil, no resistor and your set.
Hello 5.7 Hemi...
Thank you for your fast answer.... just to clarify I don´t have a MSD BOX... only a " Ready to run Distributor" and the " Blaster II " Coil.
Thank you Juergen
Short update....
MSD Blaster II coil.... MSD Ready to run Distributor.... and NO Ballast Resistor.... Works perfekt...( and one part less that can fail
:hello2:
Greetings Juergen
MSD system gets the positive power source straight from Batt/Alt system. The wires to ballast what everybody splices out is just a trigger ( turn on ) for the MSD system, no matter if Ready to Run or Module, so actually no need to bypass the ballast, just wire the existant coil wire from stock system and will work perfectly
sorry I am confused now. I'm checking several READY TO RUN diagrams and they show they are wired with ballast ?
http://www.chargerr.com/Ignition/Ignition.htm
there is shown wired just like the stock system, not just for trigger
I know Module system doesn't require really bypassing by what I explained above.
... that´s why I am confused.... called MSD ( they told me the System doesn´t need a BR ! ) But they sell the Blaster II Coil with a BR
..??? Currently I am running the coil without a BR ( but who knows how long....)
If I use the BR I don´t get 12 V to the coil / Distributor.... and perhaps the spark will be weak ..??
they sell the coil with BR if you are using stock system, just replacing the coil, but still stock ign system.
Modules sends both coil leads at the trigger order so that's why BR is not needed anymore ( although like explained, you can keep it if don't want to completelly hack up the wiring and using the original + lead of coil wire as the turn on trigger for the MSD module ). Coil is not getting constant power from ign system source, like stock system does.
But it seems RTR distributor works just like the stock system, keeping + lead of coil sourced all the time
