bigmanjbmopar
Newb with a view
I bought the starter relay and it did not fix the problem. I did do some of the tests. Here is the results and after you guys read the results I would like to know from the couple of tests given what probably isnt the problem(example starter solenoid, grounds, ignition coil, etc). I have been very busy this last weekend but I am going to do the rest of the tests this weekend and upload a video on youtube(I will give you guys the link). On test number one the ballast resistor read 0.4. On test number two can I use the key even if it isnt actually cranking? It shoots to a 1v when in cranking position, then shoots to zero after 1/3 of a second. For test number 3 in the run position the ohms were going crazy(the meter was blinking for 0s) I will youtube video that for you guys on the weekend. In the cranking postion it did 0.1 . Quick question about the starter solenoid but if it can crank with the bypass that means the starter solenoid is good right?
Shouldn't you be getting 12vdc to one side of the ballast resistor? then reduce to 5vdc on the coil side? If you are not getting 12v to the BR then I would check the ignition switch with a meter to make sure you are getting juice all the way through, Are you sure your battery has 13-14vdc?
