35 or 50 cc pump?Pump Nozzle? Tried from 21 to 37. Tried green, orange, pink cams. Slightly better with green cam compared to pink cam, but not much of a change.
Dont know what came with the engine but prolly stock. Have a very smooth idle.What cam?
Could try 13-13.5 idle. That may give enough fuel to get you through this lean spot. That would confirm idle and transfer area.
Ah, 35.35 or 50 cc pump?
Yep, adjusted at full throttle to .010. Have instant shot as soon as I touch the throttle.Have you adjusted the accelerator pump linkage to make sure it’s firmly in contact with the pump lever at curb idle so that it pumps at first touch of the throttle? There’s a dimensional tolerance to the adjustment at full throttle to prevent bottoming the pump - somewhere around .010 to .015” clearance I think.
I would do this first. Cap the vacuum advance. Set the timing 36 all in. Then see what it does. Second step would be to upgrade the front pump to a 50cc pump.Ah, 35.
Right now I am at 37 all in without vac adv.I would do this first. Cap the vacuum advance. Set the timing 36 all in. Then see what it does. Second step would be to upgrade the front pump to a 50cc pump.
Did you examine how much primary side transition slot was exposed at curb idle setting below the blades before installing the carb? Maybe the secondaries need to be opened or closed a little to get an approximately square exposure below the blades.
I installed an FBO advance limiter plate in my GTX to hold advance to around 18 deg centrifugal and run 15 to 16 deg initial. It comes off the line hard now and solved my pinging issues.
Well, you make a very good point, he says its a new carb... machining is off ?When the throttle is moved only slightly the transfer slot to throttle plate position is changed. At this point in time you are still running on the idle circuit. I would suspect your issue lies there. Maybe the idle feed restriction is too small? Transfer slot length is wrong? Another guess is the throttle shaft holes are worn and the shaft moves in the hole exposing a leak? How far are the idle screws turned out?
Doug
What about the jets? Have you tried to lean it out or richen it up a couple of jet sizes? How do the plugs look?
Good idea, check the alignment of the throttle blades as well.Yes, I also think there is something fishy with the transfer slot/idle passages.
How about too big idle air bleeds, would that cause a bog?
Mine are size 70, will try size 65 tomorrow. Just for test as I have them on another carb. Running out of options.
Curious as to why you have the rears shut down so much? I always set all 4 of mine the same.Idle feed restrictions are tunable, would need to find some bigger jets to test.
Throttle plate is brand new, though its aftermarket and Ive learned not to trust those.
Front Idle mixture screws are 1,5 turns out, rear are 1/4 turns out. 19hg vacuum at dle.
Im starting to think vacuum leak, maybe try the carb cleaner spray method.
As earlier said, first time with a four corner for me.Curious as to why you have the rears shut down so much? I always set all 4 of mine the same.
