RRSweden
My feeling was also to go with the stronger springs.It looks like the 915 springs are a stronger spring. I would use those. That 268 cam has a duration of 268/280 and a lift of .477/.480. Int/Ex. We used the next one up in my Son's 383, the XE274 H, and it worked fine with the stock 383 Magnum springs. It's best to measure spring pressure at the installed height, and open height. My guess is to have about 120 pounds closed, and 250 to 280 pounds open. Check with Comp for exact pressures, or someone here prob already knows what they need to be.
Another thing I heard was that the pushrods from 67 is taller than 68 ->. Is that because of the 67 block or the 67 heads? I have a 70 block. Just thought I'd hear if anyone here knew for sure wich ones to order, otherwise I guess I'll get a dial-rod to measure the lenght I need for the setup.
(excuse me for all the "what parts will fit" questions... But, as I said, I do have a time limit, and it takes time for the parts to ship from the US...)
