miller
Some of the other guys chime in on this one.
Though what I see, almost looks like the original cast guide busted, and without removing the upper part, reamed it, putting in a guide as a easy fix. Might be able to tell, by looking at the other end of the guide. Sure, it can be repaired (replaced), but that depends one how far you want to go on it...how bad you want to use those heads.
Probably already know this...those steel spring shims...used if the spring seats are cut, to get the springs back up to installed height.
