EngineerDoug
Hello,
It looks like I will have to include pistons & rings in my 383 rebuild, so I now have some latitude in choosing my compression ratio. If nothing else I need to decide whether I will use a steel 0.020" or an 0.038" composition head gasket. I would appreciate some guidance as to how high I should go, given the following parameters:
'68 383, 0.030" over
906 heads - don't know the chamber volume yet but will cc them
Summit K6400 cam - a mild street cam with 214/224 degrees duration @ 0.050"
3.23 gears
3400 lb Coronet
Torqueflite, probably stock converter (2BBL engine)
KB flat top hypereutectic pistons - these should be about 0.026" below the deck
I would like to use pump gas (California) without pinging issues. This will not be a long term engine for the car, but rather an interim powerplant that may see 1 or 2 years of service.
I am thinking maybe 9.5:1 would be the max for this combo, but welcome your thoughts.
Thanks!
3.23 gears
3400 lb Coronet
Thanks!
