They are all over the place (ballast values) You probably can never go wrong with a 1 ohm for all but a .25 might fry a box, really not positive like posted earlier there are no schematics on them to investigate.
Is that a P3690256?
To be absolutely assured and definitive of which ECU (blue vs orange box) is better, I would want to see a schematic diagram of the internal components and connections. This is NOT how the ECU, resistor, coil, and distributor pick up coil is connected BUT what is inside the ECU box. I'm sure my request would be ignored by the manufacturer unless l could perform a autopsy of a failed box and determine a root cause failure analysis.
BOB RENTON
Evidently there are plenty of "orange" failures out there. Someone must have a "real" Chrysler P4120505 orange that has failed they could send ya' to RE......unless l could perform a autopsy of a failed box and determine a root cause failure analysis....
I was just about to pitch my orange box that failed, but if you want to do an autopsy, I'll send it to you Bob.I'm sure my request would be ignored by the manufacturer unless l could perform a autopsy of a failed box and determine a root cause failure analysis.
BOB RENTON
Sure....upon receipt, I'll try and remove the potting compound without destroying the circuit board, and individual parts....thanks for the offer. Ill send you a PM with my contact information....I was just about to pitch my orange box that failed, but if you want to do an autopsy, I'll send it to you Bob.
Haven't seen many of the P3690256 mentioned though, that's why I asked 66Sat about. Might be a harder find to compare unless maybe Ray has one laying around.
It's on it's way to you Bob. I'm sure we'll all be interested in your findings.Sure....upon receipt, I'll try and remove the potting compound without destroying the circuit board, and individual parts....thanks for the offer. Ill send you a PM with my contact information....
BOB RENTON
Really depends what box you are running actually. Hope this helps.
View attachment 987637 View attachment 988398
Most use the 1.2 ohm ones. Check the value if you are using the single one. They can not be 1.2 They also have them in other values. You can see that in the chart.
What kind of bench tester do you use to test the Chrysler ECUs? I've seen plenty of used ECU testers (one unit for all ECU types, Ford, GM, Chrysler etc), but they seem to have Chrysler harnesses that are designed for testing the 1970's 5 pin ECUs and lean burn ECUs (late 70s).. Are you using the same test device for both 4 and 5 pin ECUs?I can test your ecu just the rides. Easy with a bench tester.
I had a USA MP Orange box on my Challenger from 1989 to 1998, and never had a problem with it..
Dunnick Racing did a lot of testing on coils and ECUs
https://board.moparts.org/ubbthreads/ubbthreads.php/topics/1230955/1.html
https://www.hotrod.com/articles/mopp-1211-3-2-1-ignition-box/
Zetron IMT 1000 Is my go to. I have had the mopar testers also but prefer this one. Same ast the parts stores used to have. It tells you what failed internally. Also does most domestics 72 to 84.What kind of bench tester do you use to test the Chrysler ECUs? I've seen plenty of used ECU testers (one unit for all ECU types, Ford, GM, Chrysler etc), but they seem to have Chrysler harnesses that are designed for testing the 1970's 5 pin ECUs and lean burn ECUs (late 70s).. Are you using the same test device for both 4 and 5 pin ECUs?
