- 3:59 AM
- Jul 1, 2015
Problem is , none of these Mopar ECUs are made anymore , and even the ones that where made the last ten/fifteen years where at best poor quality
Part I struggle with , is trying to match up all this Chinese junk today , mostly Coils/ECUs and put a decent system together with mismatched components that actually performs
Totally agree all the newer stuff sucks for sure. I try to keep the older nos/nors parts down to a decent price when I find it but it is getting really rare and the new stuff absolutely sucks.
A curiosity question....
Is the lack of a reliable, reasonably priced, available, perhaps with adjustable RPM's limited, a "universal" ECU as an opportunity to design and manufacturer what is needed? Rather than the units presently produced with the highest profit margin and lowest quality components.
I'm presently trying disassemble a failed Mopar orange box ECU, to determine which internal component failed and the reason for the failure. And possibly improving the design to eliminate the sensitivity to coil requirments and the associated switching transients and to POSSIBILITY of eliminating the need to use a ballast resistor, finally ending the ongoing controversy of the need and value of said resistor.
This effort will take some time.
Bear in mind that the coil produces the high secondary voltage when the ECU (and associated internal components) turns OFF the coil's primary voltage (and current) and therefore must absorb these induced voltage transients repeatedly, and as the RPMs increase, the peak transient voltage also increases. The coil's inductive reactance also affects the charge and discharge time as well as the associated inrush current, which requires the ECU to absorb these additional parameters continually.
BOB RENTON
