panhead
Good day,
I would be interested in a couple of them if you decide to make some
Curt
Curt
Your private message inbox is full. Sincerely Tony.TeeI know this is an older post, but are those diaphrams available?
I apologize. I didn't know if was full. I have made room.Your private message inbox is full. Sincerely Tony.Tee
Im sure the dual vacuum port servo ended in 1969 and the single vacuum port servo began in 1970. As I had both 69 and 70 chargers with speed control.So I discovered all the under dash wiring and switches for the cruise control unit seem to still to be present, so good news.
My question now is why the cruise control unit that came with the car only has provision for one vacuum line when the diagram shows two lines and the brake cutoff switch has a hose running into the engine bay? Is it the wrong unit? I have a 2nd unit off eBay that has provision for the second line.
