Brian DePouli
Installed the power steering hose and filled the pump. Also installed the correct engine to body ground wire and did the heater bypass hose as well. So wanted to turn the motor to #1 TDC to get the plugs wires right...
But I got this
The first clunk is turning the ignition on. The second is turning it to start...and then repeating.
Battery is at 12.76V
Checked the wiring all appears to be in the right spots.
But I got this
