jakepup
guys, have a few questions on what products to use on my motor, this is going in a 70 charger "hot street machine" , might see the track a few times in its life,, I couldn't find an aftermarket block so its going to be a 73' 440 .030 over with the 493 stroker kit. eagle rods, crank and diamond pistions, bds 871, 2 quickfuel e85 750 blower carbs, 9:1 compression with 6-8lbs of boost. I was going to girdle the bottom end and hope it holds together for a while until I can get a world block. anyways was kicking around the idea of the victor heads and hardland sharp rockers, would these be a good fit for this application?? after talking to the a- holes at indy I will never call there again!! any input on the best valvetrain setup for this application? thanks for any input!
