Electrical help please
BEAUTIFUL BEAST! what all is done to the motor? I have no clue if anything has been done to mine. I do know it’s still a flat tapped cam. I’d like to do something to her but not sure what to do. I don’t want anything crazy.
It's a 440 .030 over with 10.7:1 compression. Edelbrock Heads that have had a little work The old .509 purple shaft cam. Torker II intake with a 850 Billet Thumper Carb by Dominick Thumper
The Fuel system is EFI ready using a Tanks Inc EFI tank, in tank fuel pump, 1/2 inch fuel lines with 3/8 inch return line
3.91 Gear 8.75 rear with a 3000 stall Torque Convertor
My blue wire and blue with white tracer wire connects to the blue wire on the pigtail that goes to my electronic voltage regulator? And run a wire with those to my alternator field?
If you want a heavy duty adjustable voltage regulator
Transpo C8313:
Transpo Heavy Duty Adjustable Voltage Regulator C8313 - for sale online | eBay
There is an adjustment on the back that allows you to adjust the regulated voltage.
I have one on the '71 Charger regulating a 132 Amp Denso alternator with trunk mounted battery.
I adjusted the regulator for 14.0 Volts at the battery when running.
I talked to Skatpak and Redbeard last night. I’m sure I’m on the right track
I think what you mean is the brush, and yes the green goes on one, and a blue 12v to the other field.
2 field connections, one green, one blue.
Both of my field wires have this same set up in the picture
I give up for now It just fried my new fuckin harness. Did it exactly the way the pic shows. FML
What happened? If something was shorted, the fusible link should have burnt before the wiring?
2 things I'd check, are the brushes shorted to ground, and which wire was the offending burnt one.
