69RRGTX - thanks for the information - how happy are you with the way the car handles ? The ability to do a dead on alignment and hold the alignment ?
Seen posts from a couple guys that state Original Mopar components ( and some upgrades ) can make a world of difference in the handling.
Hotchkis has a showroom 30 minutes from me in Race City ( Mooresville NC ) - so that and easy option for me.
Now the big question - bolt on front ends will run you $5000 - 6000 ( + / - ) - can you share with us the cost you have in your Upgrades while keeping many Original Mopar parts ?
That would help some of the rest of us to have a comparison and use it to help us figure out our direction ( budget permitting - of course ).
THANKS
I have around 3500 in the whole works. I did already own the shocks and sway bar for the front.
Figure 375 for a steering box from Firm Feel
UCAs 325, LCAs 355 (boxed, straitened, powder coated, poly bushed w/ greasable pins)
11/16 inner/outer tie rod kit 225
1.06 t bars 355
fast ratio piman and idler arms 290 ( optional, if on a budget, do this later)
sector support kit 135
strut bars 300
So that is 2360.00, like I said I had good shocks and a nice sway bar already.
For the brakes my disco tech style 11.75" rotor complete kit was about 750.00 and very complete.
I also replaced the booster, m/c assy for 450.00 +/- ( I was not planning oin that but it helps a lot)
Cleaned and reused the t=bar adjusters, boots, clips, center link, and that is about all.
Alignment was 80.00, and it fell right into the specs Firm Feel suggested. 1/2 to -1 degree of negative camber, 4 degrees of positive caster (mine is actually at 5 ) and 1/8 - 1/4" toe in.
I have not had enough time in it to tell you how well it "holds an alignment" But with no more strut rod bushings and 6 poly bushings holding the front together, I don't see any problems. The car handles very well, and I like the stage III steering box with the fast ratio arms but I could see some people not wanting their steering that stiff. I is now a 12:1 ratio, stock p/s is 16:1, manual 24:1 so she steers quickly.
Future plans are for Hotchkis shock all the way around, and the car will be getting torque boxes and frame connectors soon.
As for the bolt in kits, I have an alterkation on my roadrunner, but it was put on for racing purposes (weight, high speed stability) I would like to build another car with the high end magnum force front end, I would just have my chassis shop fab up the rear suspension, any good one can. But I figured 20k for total suspension, brakes, wheels tires...... That will be in a few years!
Good luck to you...
