Family Tradition
time to crack the shop door!
lol!
Just gonna put the Wranglers back on and take her back country Gpuller..J/K BFG Radials on there now. When the well fills up a bit more I want to get a decent set of drag radials and rims for the misfit days on the road or at the strip.
I think I know the guy you're talking about....On that service road that runs from the backside of Fleet Farm over to Churchill Street? I heard he has a 5 Gas Diagnostic...Pretty sure I seen a '70 Roadrunner in primer on a rotisserie in front of the place last summer for sale, if that's the place you're talking about.
Yup an the RR is still there but i wouldnt touch it with a 10 foot pole.
Firestone cheater slicks with the pie crust edge and a wide, wide, wide white wall!!! Yeeeeaaaahhhh!!!
Wait.... No that's for my 51 ford 2 dr shoebox with a thunderbird FE and toploader 4 speed.... Never mind, I get confused so easily in my current mental state.
:toothy6:
LMAO!
Dave, are you hydroponic farming in your basement again?
Those ain't tomato plants.....
[video=youtube;4en77mX6gOI]http://www.youtube.com/watch?v=4en77mX6gOI[/video]
Had a friend look at it.....Funny how there's a Roadrunner parts car that comes with it behind the building that has the VIN missing and VIN cut out of the radiator core. Hmmmmm.
:upside down::upside down::upside down::upside down::upside down::upside down::upside down::upside down::upside down::upside down::upside down::upside down::upside down::upside down::upside down::upside down::upside down::upside down::upside down::upside down::upside down::upside down::upside down:
Propwash, I thought you were due for another Smiley Blitzkrieg.
Awesome build man, I can hardly wait to see more!​
Dam Will I think it's been at least a year and a half since I last was on here. Took me all day off and on reading everything I missed. I found myself multiple times wanting to respond to some of the posts then realizing it was a year old. Everything looks great I'll need to come see her one of these weekends.
Heyyy...Good to see ya Morbid. Long time, no see. Glad to see you rolling around the site. Yeah, she's a book now..lol Thanks for reading. We'll definitely have to catch up down the road. Hopefully on the road shortly or this book is going to become a mini novel set.
You know Will, some novels get turned into movies. Who can we get to play you, your wife's part? Would it be a love story, comedy, horror, or just a little bit of everything. LOL.
them apples are pretty damn sweet Will...pretty damn sweet!! and the emblem turned out great as well!!
and as always, helluva write up on welding the bung (huh-huh) to the tank!
DAVE'S NOT HERE MAAAAN lol
Thanks Mar and Roger, appreciate it. Would be a heck of a movie........maybe throw in a different motif to stir things up. How about we use this intro to kick the movie off:
[video=youtube;ezUdVg6cszo]http://www.youtube.com/watch?v=ezUdVg6cszo[/video]
Dyno is scheduled for May 7th..Rented out the machine and tech for the day. I plan on being for most of it.
Hmmm is right.If i was him i'd tell the owner to get it out of here.I think the guy owes money to my buddy so there it sits till the bill is paid
. Dropped the tank and welded in a -6AN bung for my return line.
Everything went together real smooth, better than expected. Only thing that slowed me up was setting the valves off the roller rockers (what can I say, I'm not a chevy guy!)...LOL...
A little tech write up on installing the -AN fitting install. Nothing major, but havn't done one in a while. A couple jokers at another site said MIG welding a bung into a regular fuel tank wasn't possible, I would just burn through like butter. Well......that made me want to weld one in even more!
So, I'm running a Bypass fuel regulator for a few reasons. 1) Cooler fuel. 2) Quicker response to changing conditions 3) choke out vapor lock issues 4) In general, a better regulated/stabile fuel system. The little 1/4" return port on the sending unit wasn't going to cut it. Most recommend the same size return line, if not larger. Being i'm running Stainless braided line and AN fittings all the way to the front and back, I went with a -6AN Bunn fitting for the return.
I bought a 18" chunk of 3/8" pre-flared line, cut to 9" and welded to the backside of the fitting. I used the flared side because it cups over the the inside of the AN fitting. Using the cut side I would loose some inner diameter, especially if the weld penetrated too far into the inside of the tube.
Next I bent the line. I did not want the fuel shooting straight back and turning the fuel tank into a Jacuzzi. I also didn't want it shooting straight down and boiling the fuel up like a cauldron....Hence the bend.
Drilled the hole and marked the straight up and down 12 o'clock position on the bunn. When going to weld it on I wanted the fuel to come out not only a 45* to the bottom of the tank, but also about a 45* to the side of the tank. Just to keep the agitation down. Those marks let me dial in the correct angle.
So.....can't be MIG welded eh? Hope one of the guys that was preaching that likes the picture below..I do! It was done with a Millermatic MIG welder and .030 wire!
Being this fitting is obviously subject to leaking fuel, I wanted to make real sure it doesn't leak. One way to do that is backgrind the weld. Pretty common practice out there in the real world when it comes to any kind of Code welding for pressure vessels, critical systems or something holding nasty/explosive liquids. Backgrinding into the weld will open up any kind of porosity (gas holes), undercut, fusion issues or other issues not seen by the naked eye. Kind of an insurance policy. So, wrapped the threads (wouldn't want to turn a fairly easy job into a real PIA job with a slip of a die grinder) and ground the cap back down.
Everything looked pretty good so I welded up another pass, background/cleaned up the weld a bit and coated with some Zinc based weld thru primer (being I removeD the galvanized coating in the area for better arc). Coated with rust bullet after that.
All said and done, I hooked up my 6HP Shop-Vac and sucked anything I could out of the inside of the tank. Worked pretty well because the tank popped in about 25% (had to reverse it to pop it back out..lol). I also dumped in about a half a gallon of mineral spirits, sloshed it around and dumped. Tank is nice and clean inside, better than when I got it.
Kind of a pretty small task, but wanted to show it can be done, and easily for that matter. The benefits of running a return line are non arguable. It's simply a good system to run. So..Hope it helps someone out someday.
Nice job, well done Prop... I just want to add flowing fuel pressure, is much better than dead heading, like a typical regulator does...
that 512 bullet looks badass! the emblems look right on as well nice stuff! man you can taste it now I bet.
Excellent job on the emblems Will! Everything looks like its coming along super great Man, i can almost hear the video with the engine screaming.. Bad to the bone mean she looks!!
Thanks Bud, Charger and Ron! You bet fella's.......Ships about ready to leave port! What the heck I'm gonna do with myself after that?............not a flippin clue..lol Have a good weekend fella's!
